Alfaromeoguy
Alfaromeoguy Reader
4/27/19 1:13 a.m.
On my steering  arms to rid bumpsteer,i have 3 spacers  and on the other side I have 2 spacers,(   outer link, drag link, outer link system) I have a not too sure feeling on driving like thid8, so do I replace the 3/4inch stack of spacers with a solid  with a 3/4spacer? 2nd photo is not the finished bumpsteer fix. Just a starting  point, and to give you folks an idea how my steering system is set up.
Alfaromeoguy
Alfaromeoguy Reader
4/27/19 2:16 a.m.
But have no fear, I bought very long bolts so all the spacers I will need, will be on the shank of the bolt. Not the threads. After I finish the finel settiings ,i will remove  the  bolts,and cut any excess  threaded  part of the bolt. Grade 8  5/8 bolts and grade  8 nylocks.
Patrick
Patrick MegaDork
4/27/19 6:14 a.m.
I used tube that has the ID of my bolts and cut exact spacers from it.
ChasH
ChasH New Reader
4/27/19 9:11 a.m.
Can the arms be swapped side to side to reduce the length of the bolt?
Birthdays
0wrsxtvEc4skHHj3IfXiVAEPJ4OgRoJxWt29OjQBt4PRMtVCHEMdKsoFPDfO9R5X
