03Panther
03Panther UltraDork
6/15/21 9:43 a.m.
In reply to alfadriver :
Thanks. At 140 for parts, vs 300 the easy button was almost worth it. Back when I made decent money, I'd have gone that route as well. Today, I'd have to modify used parts and buy just the minimum... or pretend they worked!
alfadriver
alfadriver MegaDork
6/15/21 10:11 a.m.
In reply to 03Panther :
To be clear, I didn't buy parts, I bought two complete brake assemblies - one for each side.  Unbolt the old, bolt on the new and connect the wires- done.  If the shoes ever wear out, I'll probably do the same thing, as I'd expect a lot of rust and the magnet puck will be pretty worn by then, too.
The one thing I am not doing is changing the brake drum, which would also change the wheels.
vwcorvette (Forum Supporter)
vwcorvette (Forum Supporter) UltraDork
6/15/21 4:26 p.m.
03Panther said:
Correct. Larger diameter pin at that point in red on your image.
Any reason I can't move the slipper between the larger pin and the frame to lower it? Any reason I shouldn't lower it? I would think lower center of gravity would be a good thing.
I can't se any reason. Extra bracket length hangs down a bit, but I would not expect a clearance issue there.
Agreed. Think I'm gonna be lowering the trailer. To go with my lowered Safari!
03Panther
03Panther UltraDork
6/15/21 6:55 p.m.
yes
hF2FfM6JSFJrFcBZvXumtHWkZjfdgfWNG2TskQgHRlbdOCjdjNkETafgC3tNmCcf
