rslifkin
rslifkin UberDork
2/8/21 6:15 p.m.
Pump in tank has a few benefits: the fuel around the pump keeps it cooler.  It absorbs more noise so you don't hear the pump as much.  And the pump isn't exposed to the weather so it doesn't corrode.  That said, the lack of access hatches over the pump in so many vehicles (not just GM) is stupid.  My Jeep requires either cutting or a tank drop to change the pump, for example.  BMW was nice enough to provide access from inside, on the other hand.
All I hear from you is complaining about how everything modern is awful, can never work, how we were better off with carbs and points that required constant fiddling just to run poorly, get 5 mpg, etc.  Go crawl back into your luddite hole.  EFI, electric fuel pumps, etc. have been here to stay for 30+ years.  Learn how to work on it, suck it up, deal with it and quit bitching about it.
Paul_VR6 (Forum Supporter)
2/8/21 6:17 p.m.
Think of it this way, them making all EV will make things an order of magnitude simpler for them. Not as much plumbing to worry about. laugh Maybe they can finally make something that's not a POS.
ProDarwin
ProDarwin MegaDork
2/8/21 6:18 p.m.
This isn't a modern car/overcomplexity/fuel injection issue.  Its a design/GM issue.
On cars with an access door over the pump it is no big deal.
Teslas don't have in-tank fuel pumps FYI.  Edit:  Too late.  Damn.
pres589 (djronnebaum)
2/8/21 6:31 p.m.
I think that line of cars from GM were pretty good at killing fuel pumps.  I've known a couple of people who had weak/dead pumps in Centuries over the years.
Not sure if it's worth fantasizing about violence over.
1988RedT2
1988RedT2 MegaDork
2/8/21 6:43 p.m.
For the record, I tried to upvote the OP's post because it really is an awesome rant and I felt it deserved recognition, but it didn't register.
It takes all of 10 minutes to cut an access so it's really not that big of a deal.
My only other suggestion is to buy older cars. Then you can bitch about setting dwell or float leveles. laugh
Tom Suddard
2/8/21 6:47 p.m.
I don't get all the hate for in-tank pumps. Yeah, you have to drop the tank, which adds a few hours to the job. For a part that needs replacement maybe once in the car's lifetime? Doesn't seem like that big of a deal. That said, an access hatch is nice. But that costs money, and people complain when premium cars (which often have niceties like pump access hatches) cost more money.
Tom Suddard
2/8/21 6:48 p.m.
Also, my electric car has needed zero maintenance, service, or attention aside from wiper blades and washer fluid over three years of ownership....
In reply to Tom Suddard :
It's a GM. It's going to need more than one pump.
Tom Suddard
2/8/21 6:51 p.m.
In reply to Toyman01 (Moderately Supportive Dude) :
I said the life of the vehicle. Since it's a GM isn't that about 75k miles? cheeky
Stampie (FS)
Stampie (FS) MegaDork
2/8/21 7:00 p.m.
In reply to RichardSIA :
Should we stay off your lawn also?  At least it's not a Volvo S40 alternator.  I was told those required dropping the front subframe.
Stampie (FS)
2/8/21 7:00 p.m.
My 99 truck is about to hit 200k thank you very much.
2/8/21 7:05 p.m.
I know there are a bunch of EFI German cars with inline external Bosch pumps. Used one on my MGB when I put in a fuel injected engine :) Used another on my Seven with the EFI Miata engine.
I'll probably replace the MG one with an in-tank for better packaging.
2/8/21 7:18 p.m.
Miata has an access panel for the fuel pump. smiley
Tom Suddard
2/8/21 7:26 p.m.
In reply to Keith Tanner :
This is true. My go-to external pump for EFI on cheap old cars is the pump from an '88 Ford F-250 with a 302 and fuel injection. Every single parts store carries them, they fit anywhere, and they come with 5/16" barb fittings.
2/8/21 7:29 p.m.
I needed this information before I put a weird German pump in my MG :) Good to know.
Flynlow (FS)
Flynlow (FS) HalfDork
2/8/21 7:31 p.m.
I've had my '88 Camaro since high school, dropped the tank twice on it.  Also helped people replace the pumps on Suburbans or Full-size vans (both of which look more similar to the Camaro underneath than I'm comfortable with).
When I got my '84 200SX in college, and the pump went out within the first couple of months, I was dreading the job, setting aside a whole weekend, not realizing there was a better way.  20 minutes and an OEM access hatch had me scratching my head and wondering "Why doesn't every OEM do this?  They must do competitor benchmarking, don't they?"
Good luck!
gearheadE30
gearheadE30 Dork
2/8/21 7:32 p.m.
Those Ford inline pumps are great; I've used one in an early E30 with enough success that I never got around to replacing it with the correct pump.
As annoying as in tank pumps can be, I've had far fewer problems with fuel starvation with them. Most in-tank pumps have a housing or a bowl of sorts that holds fuel around the pump. While I'm sure the intent was to prevent the pump from overheating and burning up with low fuel level, it sure does help with preventing starvation on curvy roads.
2/8/21 7:55 p.m.
It takes like ten minutes to drop the tank on a Century, on jackstands, in a snowy driveway.  BTDT
2/8/21 8:03 p.m.
We had the pickup on one of our enduro Miatas so dialed that of the engine coughed in Turn 1 at Thunderhill, you weren't going to make it to the pits :) It would run on ounces of fuel.
No reason why a good sump with an external pump couldn't be the same, though.
Stefan (Forum Supporter)
Stefan (Forum Supporter) MegaDork
2/8/21 8:05 p.m.
On most of my 80's FI Chrysler's I didn't even have to drop the tank, just lower the rear axle off the shocks and rotate the locking ring.
Im sure others have had to replace fuel system parts on vehicles after 30 years, so why is this any different?
Rons
Rons HalfDork
2/8/21 10:17 p.m.
In tank and having to drop the tank is an issue with at least Ford and GM. One of my cousins was a body man and had to drop the tank of a Crown Vic, and unfortunately the half full tank dropped and knocked over the trouble light. No one was injured in the ensuing fire that destroyed the shop. I hate tanks that have to be dropped. Most Japanese cars have an access panel under the rear seat or in the trunk and that makes life much easier.
2/8/21 10:25 p.m.
Ah, for the days of Range Rover Classics or Defenders, where you could access the pump by simply cutting a hole in the floor :)
grover
grover Dork
2/8/21 10:50 p.m.
Hey now! My classic had an access door. I changed the pump in about 30 minutes in the driveway. One of the easier jobs actually.
grover
grover Dork
2/8/21 10:51 p.m.
I've done several as well, but the only one that didn't have access was an Obs Ford. Had to take the bed off.
Birthdays
wJMF6Zl54Joho9HRyVyQ446GzUkqFO71rWiB023QnFjBu3AeXkLCNIrh9pAjy2Gn
