MCarp22
MCarp22 Dork
10/10/15 7:49 p.m.
dooodstevenn wrote: All this talk about motion ratios and rates (in Hz) has left me even more confused.
Hz is a nice way of comparing spring rates between dissimilar suspension setups.
flatlander937
flatlander937 Reader
10/10/15 8:57 p.m.
Yep.
Read here and click around for more info:
http://farnorthracing.com/autocross_secrets5.html
FWIW with struts and FWD the 2.2-2.5hz thing may be a little light based on some other successful FWD setups.
MCarp22
MCarp22 Dork
10/10/15 11:49 p.m.
flatlander937 wrote: FWIW with struts and FWD the 2.2-2.5hz thing may be a little light based on some other successful FWD setups.
Possibly, but have we established what the OP is doing with the car before jumping right into nationals level autocross setups?
dooodstevenn
dooodstevenn Reader
10/11/15 3:55 a.m.
In reply to MCarp22:
No Auto X, just HPDE.
flatlander937
10/11/15 5:49 a.m.
Well that's some important info then. I didn't read hard enough into the "banked corner" part the first time.
FWIW a national 2 driver did a time attack yesterday with 700/600 rear, running TWO heavy rear sway bars, no front bar, and loved it FWIW.
MCarp22
MCarp22 Dork
10/11/15 6:49 a.m.
Keep in mind, the 2 has an axle and doesn't get toe changes the same way as the 3's multilink.
dooodstevenn
dooodstevenn Reader
10/12/15 4:17 p.m.
MCarp22 wrote: Keep in mind, the 2 has an axle and doesn't get toe changes the same way as the 3's multilink.
What is the equation you used to calculate natural frequencies based on motion ratios you posted about earlier in the thread?
MCarp22
MCarp22 Dork
10/12/15 4:57 p.m.
Assuming you're using lbs/in:
3.14 * ((({springrate} * ({motionratio}^2)) / {cornerweight})^(1/2))
flatlander937
10/12/15 6:31 p.m.
I use this calculator here:
http://farnorthracing.com/autocross_secrets16.html
Tire spring rates will technically bring down the frequency too. That's a bit more interesting to calculate.
Birthdays
jWQBKAXNz1B4BkqA9pYAfutwac8n3YuAR4J29EsmnX11hRwAs96N3HXia2Ere5QD
