Thinkkker
Thinkkker UltraDork
11/3/12 6:45 a.m.
We used veggie oil in our truck when we went to TX last year. We had barrels in the bed with a bed cover/camper over it all. We tried to gravity transfer, but that took a long time. So, I bought a rotary pump trying to keep our monetary output down http://www.amazon.com/TERAPUMP-ROTARY-HAND-MANUAL-BARREL/dp/B0026JG7EQ/ref=sr_1_3?ie=UTF8&qid=1351942456&sr=8-3&keywords=rotary+barrel+pump To make this work faster, I used a piece of pipe, with a lock bolt on it to fit onto the piece where the handle fit on and had another bolt that stuck out for a drill to fit on. This allowed for the drill to be the power on the pump.
This would pump faster than you could use to fill a tank on a vehicle, so moving into a open tank as you speak it would only take a few minutes.
lastsnare
lastsnare New Reader
11/3/12 8:31 a.m.
good suggestions, thanks you !
DrBoost
DrBoost PowerDork
11/3/12 10:05 a.m.
Thinkkker has it. Trust me, listen to the veggie oil people. We do nothing but move oil all day long. I can pull 12 gallons of crappy veggie oil at 10*F in 2 minutes with no moving parts (vacuumed tank). If this is a one time thing, you have a lot of options. If this is going to be a regular thing, you want to make it easy and reliable.
lastsnare
11/3/12 10:11 a.m.
I like this solution. In your experience, does the drill seem like it has to work very hard ? And by that I mean, does it seem like you would go through a few drills now and then, or does the whole system seem to be pretty reliable and efficient ? (relative to the cheapness)
Thinkkker
Thinkkker UltraDork
11/3/12 10:21 a.m.
The drill doesnt work hard at all. We went 1600 miles, stopping every 350-400 to refill on the truck, still using the same battery till the last stop. Its a old 19.2 volt craftsman.
The thing to watch, is to make the piece close to square when you weld it up if you weld it, I got it off a little so that was the only issue, but it still worked just fine.
lastsnare
11/30/12 9:50 a.m.
Just to bring closure to this thread, this is what my friend ended up using (I just saw him post a picture of it today):
He said it's a "Graco Quiet Fire Ball Air Powered Pump"
44Dwarf
44Dwarf SuperDork
11/30/12 11:35 a.m.
Trouble with grayco or double diaphams is noise.
We use theses to pump hydrolic oil out of drum and another for used out of the sumps. 2 12ft garden hoses one cut in half with 4ft of 1/2 inch conduit hose clamped for the "probe" end.
16vCorey
16vCorey PowerDork
11/30/12 11:54 a.m.
We have a waste oil heater at work, and we use these tubs.
They have a pretty large opening on top, so it's easy to dump the oil from pretty much any container. When we need to fill the heater, we just pick it up with a forklift and it's got a ball valve drain with a 90* on it so you can just pour it right in.
GrtYmZ9Bqhr02ZmLJzgFn4G6i4VIaglXRq9VHjn69CTZLxk9O6fAaOBpvQ0PcAlH
