Knurled
Knurled Dork
2/27/12 7:35 a.m.
Twin_Cam wrote: 4-1-2-3. The Saturn's firing order is written on a little sticker on the front crossmember above the radiator. Not nearly as badass as stamping it onto metal...
That's not really the firing order, that's the coil wire order, which is damned important on a Saturn because they use the difference in resistance between #1 and #4 firing instead of a cam sensor.
pinchvalve
pinchvalve SuperDork
2/27/12 7:37 a.m.
Mine is: 1-14-9-4-7-12-15-6-13-8-3-16-11-2-5-10. W16 engines are a little odd.
Don49
Don49 Reader
2/27/12 8:18 a.m.
1243 Ford cortina
Twin_Cam
Twin_Cam SuperDork
2/27/12 9:23 a.m.
Touche. Then I don't know what the firing order is. But I assume it's something similar, because 1 & 4 and 2 & 3 move together when you spin the crank.
ReverendDexter
ReverendDexter SuperDork
2/27/12 9:56 a.m.
1-3-7-2-6-5-4-8 and 1-5-4-2-6-3-7-8
Same displacement, same manufacturer, and the first one is definitely more fun.
Taiden
Taiden SuperDork
2/27/12 10:04 a.m.
Why would a manufacturer start with the 4th cylinder?
Hungary Bill
Hungary Bill Reader
2/27/12 11:23 a.m.
I'm surprised to see so many 4-7 swappers here, I had no idea that cam was so popular!
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
2/27/12 11:31 a.m.
Lessee i've got:
1-3-4-2
1-3-4-2
1-3-4-2
1-5-3-6-2-4
1-2-3-4-5-6
Rufledt
Rufledt Dork
2/27/12 11:52 a.m.
ReverendDexter wrote: 1-3-7-2-6-5-4-8 and 1-5-4-2-6-3-7-8 Same displacement, same manufacturer, and the first one is definitely more fun.
Unfortunately I only have the 1-5-4-2-6-3-7-8 version... Also a one of these:
Wifey has a 1-4-3-2
1988RedT2
1988RedT2 SuperDork
2/27/12 12:29 p.m.
Brett_Murphy wrote:
1988RedT2 wrote:
One revolution of the engine would be: (L1,T1-L2,T2)-(L1,T1-L2,T2)-(L1,T1-L2,T2)
One revolution of the eccentric shaft or one revolution of the rotor?
Brett_Murphy
Brett_Murphy Dork
2/27/12 1:34 p.m.
In reply to 1988RedT2:
That's the firing order for one complete revolution of each rotor.
The eccentric shaft is spinning three times faster than the rotor, as you can see by the letter B vs. the letter A.
D4rIEpkbx4kReYocltaIEkxruUBcPUfMwq4SQRLyIwWjZKLOsjjJBLwjVw1eOY2C
