I’ll give you a different take on my tractor experiences. I bought one and promptly sold it.
We have 6 acres and when I found a smoking deal on a John Deere 4300(33hp) tractor. I figured we could use it and all of the included attachments to do just about anything that would come up around the property. It came with a full Curtis cabs/heater & fan, 420 front-end loader, 3-point weight box, 72" belly mower, 50" front mount snowblower, 503 rotary pull-behind mower, power beyond kit, JD yard cart and a pull behind seed spreader!!! Great deal right? Well, I thought so until I began to use it.
Our property has an 800’ long driveway that curves down to the parking area in front of the house. In the winter, we do get some ice build-up down there due to grading. I soon found out that even in 4wd, it doesn’t move on even the slightest bit of ice. After spending $400 on chains, I was able to get it to go up the driveway a few times when spring finally arrived. As soon as the yard began to dry out, it was time to explore the lifting and digging abilities of my new toy. The first thing that I found on my unit is all of the functions of the bucket or backhoe went through a SCV(single control valve). I’ve run small construction equipment in the past with some decent success and just couldn’t figure out why running the JD was so slow. Turns out SVC only functions one single valve at a time hence “single control”. There is no driving up to a pile of dirt and plunging in, lifting up and curling in one smooth motion. It required 3 separate and SLOW motions. Not what I was used to and happy about the function. Same with the backhoe function, slow, jerky and generally inefficient.
Next issue was using the belly or PTO brush hog. I soon found out that the elevations in our back yard, angels/slopes are not at all friendly to a tall and narrow tractor. It’s a huge “pucker-factor” the first time you are on even a 5° slope! Not fun! I’m sure the smaller tractors don’t have this issue since they are considerably shorter.
So, the condensed version is that a tractor just did not do for me what I thought it would do. Luckily, I was able to quickly sell the entire package and even made a few $$$ in the transaction.
Fast forward and I ended up getting two new toys to replace the JD. First is a Husqvarna commercial zero-turn mower to take care of all the grass and scrub we have. A total of 2 acres +/- and it works flawlessly, is 4x’s quicker and I don’t feel like I’m going to die driving it around. Second is a John Deere 270 skidsteer. This has become my “go-to” machine for most of my property maintenance. It moves boulders, topsoil, gravel, modified, pallets of field stone, mulch, pulls stumps and of course digs. When I got it, there was only a smooth edge bucket included. Over the next year, I bought pallet forks, a stump bucket, a rock rake and a bolt-on tooth bucket edge. I don’t think that I can ever live without a skidsteer again. Luckily, a neighbor has a much smaller New Holland skidsteer as well as a backhoe attachment, so the few times I’ve needed to dig a ditch, I can go grab his attachment, throw it on my machine and get working.
We have 6 acres right now, but if we ever move, it will be to a property with more acreage and both of these machines will go with me. I will always own a skidsteer, it’s my choice for a yard machine.
My experience and .02¢
