1988RedT2
1988RedT2 UberDork
6/5/13 10:42 a.m.
And I know there's more than a few of you here!
Many moons ago, a friend gave me an old Marantz Model 2220 receiver. Looks like it was made in 1973 or '74 and packs a whopping 20 watts. It sits in the garage, and it still works pretty well. It has, near as I can tell, two problems. One is the volume control is all scratchy, and two is the balance control shaft is bent, and might be the cause of some of the scratchiness.
Can I get parts? Where?
I suspect some of you will suggest tuner cleaner or some such, but I'd really rather get new pots, rather than try to clean up the old ones, which I suspect are well past their prime based on the way they feel.
Not mine, but it looks just like this:
e_pie
e_pie HalfDork
6/5/13 10:52 a.m.
The scratchy volume knob is likely from dust, if you spin the knob a bunch (while it's off so it's not noisey) it should knock the dust out and work fine.
1988RedT2
1988RedT2 UberDork
6/5/13 11:19 a.m.
e_pie wrote: The scratchy volume knob is likely from dust, if you spin the knob a bunch (while it's off so it's not noisey) it should knock the dust out and work fine.
I've spun it a bunch. It doesn't change.
N Sperlo
N Sperlo MegaDork
6/5/13 11:30 a.m.
UNPLUG IT, open er up, get a corrosive controlling spray or something similar and clean it with that.
Parts would likely have to be fabbed.
Swank Force One
Swank Force One MegaDork
6/5/13 11:36 a.m.
Get some DeOxit spray from PartsExpress.
Be amazed.
1988RedT2
1988RedT2 UberDork
6/5/13 11:45 a.m.
Swank Force One wrote: Get some DeOxit spray from PartsExpress. Be amazed.
I'm pretty hard to amaze. I'm not sure that removing the scratchiness would do it, but if that stuff can straighten the Balance knob shaft, I will truly be amazed!
So no parts, eh? They're just potentiometers.
Swank Force One
6/5/13 11:53 a.m.
It'll probably help/fix the volume control scratch.
But.... the balance shaft, nah.
I think there's still parts available for these, but they aren't cheap. This is one of those times you need to hop on ClubPolk or Audiokarma maybe and see if anyone has anything.
paranoid_android74
paranoid_android74 Reader
6/5/13 3:13 p.m.
I'd try these folks, they probably have something close :
http://www.tubesandmore.com/
In reply to 1988RedT2:
1988RedT2
1988RedT2 UberDork
6/5/13 6:35 p.m.
paranoid_android74 wrote: I'd try these folks, they probably have something close : http://www.tubesandmore.com/ In reply to 1988RedT2:
Wow! That's amazing! I need to pull it apart and put a meter on it and see if they have a replacement. I have bookmarked that site! Thanks!
yLPhoMnYd77B20LJKIQPb3Rod5vTV1LbexF6YKjVQm842zyREq0SDfAXblVAEvhp
