Darwin, I need some help here. I am trying to fix the car a bit. I moved the toe adjustment from the Kunos NA, which seems to work fine (there was some wierd text in there that was probably causing issues), but when I move the brake adjustment and power setting from the setup.ini file, the Brake Power and Bias Adjustment never show in the setup on track. The Setups menu in CM does show the Brake Power, but doesn't show the Bias Adjustment! Any ideas?
Here is the Generic part of the setup.ini file. Do you see any issues?
(if you do just fix it yourself, please delete the all black livery, it lacks style
, If you want to put in your own, this would be a good time.)
;GENERIC
[FUEL]
SHOW_CLICKS=0
TAB=GENERIC
NAME=Fuel
MIN=5
MAX=48
STEP=1
POS_X=.5
POS_Y=0
HELP=HELP_FUEL
[FRONT_BIAS]
SHOW_CLICKS=0
TAB=GENERIC
NAME=Brake Bias
MIN=52
MAX=80
STEP=1
POS_X=.5
POS_Y=1
HELP=HELP_BRAKE_BIAS
[BRAKE_POWER_MULT]
SHOW_CLICKS=0
TAB=GENERIC
NAME=Brake power
MIN=80
MAX=100
STEP=1
POS_X=.5
POS_Y=2
HELP=HELP_BRAKE_POWER_MULT
I'll add brake bias adjustment, but toe should already be there:
ok I uploaded a version that has brake bias adjustment. Its also cockpit adjustable
Did you clean up the toe setup.ini part? There was some strange text in there. Someone was saying the could not adjust one of the wheels.
Highlights. This is a long one. Remember, no special editing was involved....
Mike924
HalfDork
4/30/23 10:02 a.m.
Great video of our highlights there AirCooled. It shows how hard we really are trying. That "bump" in the first race, didn't even look like a bump, very odd.
MKirby
Rodan
SuperDork
4/30/23 10:20 a.m.
Thanks again to Air for putting up the highlight reels!
The 'torpedo attack' definitely looked like a glitch of some sort in the slo-mo...
Well, that explains things. I also did not realize I punted Gameboy as badly as I did.
OK come on guys, I'm not that good, right? I clearly took a frame shot then stretched Deans car to make it look like it reached out (that's why the sound cuts out). It was SUPPOSED to be funny (and obvious)!
Oh well, I guess I should have done this, and added a farting sound or something!!
I should be around tonight getting some practice laps in tonight.
Well don't go too fast. I have a couple of tenths on you!
MKirby
Everyone needs to update there car with the revision that Pro has posted up in the google drive.
In reply to Mike924 :
Lol. I need someone to race with. Last week I was running solo until Gameboy had an off and then he and I had some good racing.
Rodan
SuperDork
5/3/23 8:08 a.m.
Is this a new update, or the one that was up before last week's race?
It's new. It should add brake balance adjustment, and might fix the toe adjustment issue (?)
Rodan
SuperDork
5/3/23 4:45 p.m.
OK, I got it downloaded... lost a couple of liveries (mine and 'Duct Tape'), which I replaced from the previous files... gained cockpit brake bias adjustment... no change to the weird one-wheel toe adjustment.
In case anyone is looking, it doesn't appear to have a brake bias adjustment in the setup screens, just from the cockpit while driving. Also, IIRC the number displayed is the percentage for the FRONT. Please correct me if I'm wrong...
# is always for the front. You should be able to see it from the setup screen, and you should have toe adjustment on all 4.
This car is weird. You can try deleting the car and reinstalling.
Air. If you get in car from my car for the first race I managed to thread the needle several times on the first lap of the first race.
Yeah, it was a pretty wild race in general for me. I will be curious what I can capture.... and see if I can find an explanation for the latest "shooting off the road all of a sudden" incident....
Some highlights. Lot's of kitty stuff in this one....
I did not spot Dean's latest "incident", so not sure what he did this time! Was it that spinout on the front straight that is shown? I probably could figure out a way to blame Dean for that....
Cadwel Park tonight. The track on on the drive. A rather narrow track, but should make for some interesting racing and in general a good track for this car. I was worried AMP would be a boring race, being a more narrow track, but it was one of the more eventful races we have had!
This track has a LOT of run off in some areas, so we may end up with some out in the cornfield!
I really like this track. The last section is really fun if you get it right. turn one and two are going to be interesting. I don't want to be on the outside of either on the first lap.
