noddaz
noddaz Dork
1/9/16 6:53 p.m.
I am sure people have thought of this. I just got myself a gas powered pressure washer and was thinking of running hot water through it. Straight out of the hot water tank. Any reason I shouldn't? (And no, I didn't read the instructions.)
Trans_Maro
Trans_Maro PowerDork
1/9/16 7:05 p.m.
I used to fix these things for a living.
The valves inside a pressure washer have a plastic cage holding the valve together. Hot water will soften or melt the plastic and cause it to fail.
You're not the first guy to think of it. I met some of the others.
Proper hot water pressure washer heat the water after the pump.
Ficko
Ficko New Reader
2/5/16 2:50 a.m.
I have it, and it really works perfect.
Woody
Woody MegaDork
2/5/16 6:52 a.m.
I've been running the hot water through the same electric power washer for 20 years.
COfUCnMvEaxyS2HKmRPxaFxVJQXpshdsWlQw6B7JQ4unWNXBQbTJgFEMSsKboMHA
