TIGMOTORSPORTS
TIGMOTORSPORTS HalfDork
2/15/17 5:47 p.m.
nmna close to $2K - this looks very clean
https://knoxville.craigslist.org/cto/6001984332.html
84FSP
84FSP Dork
2/15/17 6:14 p.m.
That plus srt4 powa would be much joy.
2/16/17 7:13 a.m.
Wow!
stan
stan UltraDork
2/16/17 7:18 a.m.
Cleanest I've seen in ages:
Auto:
TIGMOTORSPORTS
2/16/17 8:43 p.m.
In reply to stan:
It is super clean. And the stripes are intact
stan
stan UltraDork
2/17/17 7:59 a.m.
TIGMOTORSPORTS wrote: In reply to stan: It is super clean. And the stripes are intact
Looks like someone took pretty good care of that trucklette.
Ashyukun
Ashyukun SuperDork
2/17/17 9:46 a.m.
That's apparently in London, about halfway between Lexington and Knoxville. I've got to admit, that's probably the best looking Rampage I've ever seen. If I could sell the Patriot today for what I have in it, it would be sorely tempting to try and get that for $2k and just take it to the Challenge as-is.
randyracer
randyracer New Reader
2/18/17 10:36 p.m.
"body needs work"... whaaa? Where? I love it, so clean. Autotragic. Stick would just rock that thing.
Stefan
Stefan MegaDork
2/18/17 11:57 p.m.
Stick swap is pretty simple since it's a cable operated clutch. If you go SRT4, then you only need another hole in the firewall for the shifter cable and fab a hydraulic clutch master cylinder mount.
Bodywork is likely leaking at the head of the bed where it meets the cab and at the cowl where the old sealant putty has dried out and cracked. Also the window sweeps dry out and fail and allow water into the doors and the floors.
They are rated for 1000lbs in the bed, which is more than an El Camino of the same vintage and the stiff rear end actually makes for a decent autocrosser, provided you swap the rack for a quick ratio unit and stuff the fenderwells with rubber.
There was a factory bed cover, that was a multi-piece folding affair.
The Shelby Charger nose is a direct swap along with the seats and front suspension and rear spindles.
rhs9NUzfLAIPMgZ9DkdEtXQGpxzXp81mf4SVS4uGq1THrONvxOYLft0PsmNy6XoV
