sanman
sanman HalfDork
3/17/15 3:01 p.m.
It's time to get the mr2 up and going again I need new tires for the stock wheels and wanted to get something for e stock auto-x and occasional street use until I puck up some 17 in wheels and tires for the street. Any suggestions? I know the stock tire sizes are hard to come by on 14 in wheels.
captdownshift
captdownshift SuperDork
3/17/15 3:19 p.m.
is Toyo R888 too focused for your use?
BoxheadTim
BoxheadTim UltimaDork
3/17/15 3:26 p.m.
I'd see if I could find a set of 15" stock wheels, that might help (albeit only a little).
I run BFG Rivals on my Turbo, IIRC I had to downsize the rear from 225/50/15 to 225/45/15 at the rear and it took/takes 205/50/15 on the front wheels.
Toebra
Toebra New Reader
3/17/15 3:37 p.m.
Even if 14" is stock size, you can go up an inch in diameter and still be legal in stock, has to be same width. I think the offset has to be the same, or about the same, you would have to check that.
If you are someplace hot, RS3 Hankooks work
sanman
sanman HalfDork
3/17/15 3:46 p.m.
If I come across a cheap set of 1993 wheels, I plan on picking them up, but not looking to spend money on a third set of wheels. If it comes down to that, I am putting on 17s and my trd springs and letting then class me as they will.
cmcgregor
cmcgregor Reader
3/17/15 3:47 p.m.
What's the stock size? Dunlop Direzza ZII Star Specs are available in 185/60r14
sanman
sanman HalfDork
3/17/15 3:50 p.m.
I believe 195/60r14 (front) and 205/60r14 rear.
moxnix
moxnix HalfDork
3/17/15 3:56 p.m.
If you are sticking with 14" wheels your only somewhat competitive option is the Dunlop Direzza ZII Star Specs.
chuckles
chuckles HalfDork
3/17/15 4:26 p.m.
cmcgregor wrote: What's the stock size? Dunlop Direzza ZII Star Specs are available in 185/60r14
This is a good tire.
bmw88rider
bmw88rider HalfDork
3/17/15 6:00 p.m.
use the allowance to go up to the 15" and run the 195 front and 225 rear tires in whatever flavor you like.
sanman
sanman HalfDork
3/17/15 8:55 p.m.
I'm wondering if 175/70r14 tires can be substituted for the 205/60r14 as the tire calculator shows that diameter should be about equal and it appears to have more variety.
Mr_Clutch42
Mr_Clutch42 Dork
3/17/15 9:04 p.m.
captdownshift wrote: is Toyo R888 too focused for your use?
That tire is only for Street Prepared and up classes.
Kenny_McCormic
Kenny_McCormic PowerDork
3/17/15 10:44 p.m.
Federal 595? Pretty sure it comes in those sizes.
evildky
evildky SuperDork
3/18/15 1:44 p.m.
The shaved yokohama was the tire of choice for ES.
Will
Will SuperDork
3/18/15 5:44 p.m.
Is the Yoko 200tw? I thought all the Miata guys loved the 195-15 Toyo (now available in 200tw).
As the owner of an SW20, I think the OP may find that the Dunlop is the ONLY performance-minded 14, but it's pretty short compared to the stock tire. MR2s run out of gear pretty early as is.
As for the Federal 595s--there are two different models of that tire. I checked a while back, and IIRC, I don't think the good one is the one available in the OP's size.
sanman
sanman HalfDork
3/18/15 8:21 p.m.
Hmm,so now the question becomes whether I go 15 inch and stay with the e stock plan or just go 17 inch and call it a day. Are there enough 15 inch options around that make decent street tires for the stock 15s? I like the Dunlop for price, the toyoR888 is super expensive.
BoxheadTim
3/18/15 8:25 p.m.
sanman wrote: Are there enough 15 inch options around that make decent street tires for the stock 15s?
Short answer - no. Usual problem at least for turbo people like me is finding rear tyres in the correct size.
I'm probably going to 17" before I have to replace the Rivals.
sanman
sanman HalfDork
3/18/15 8:33 p.m.
Tim, For 17 in ASA AR1 on tirerack come in the correct sizes and offset for not rolling the fenders, but is heavy. I may have to hunt down some g35 17 inch wheels.
evildky
evildky SuperDork
3/23/15 3:59 p.m.
Will wrote: Is the Yoko 200tw? I thought all the Miata guys loved the 195-15 Toyo (now available in 200tw). As the owner of an SW20, I think the OP may find that the Dunlop is the ONLY performance-minded 14, but it's pretty short compared to the stock tire. MR2s run out of gear pretty early as is. As for the Federal 595s--there are two different models of that tire. I checked a while back, and IIRC, I don't think the good one is the one available in the OP's size.
Dang, meant Toyo, typed Yoko. I typing it now I can see why I screwed that up.
iceracer
iceracer PowerDork
3/23/15 6:13 p.m.
sanman wrote: I'm wondering if 175/70r14 tires can be substituted for the 205/60r14 as the tire calculator shows that diameter should be about equal and it appears to have more variety.
Going to a narrower and higher a/r is not the way to go if you are looking for handling.
mr2s2000elise
mr2s2000elise Reader
1/22/19 10:13 p.m.
Any reason on the downsize?
I am am looking for new tires on my sw20
Will
Will UltraDork
1/23/19 5:48 p.m.
In reply to mr2s2000elise :
I just put new rear tires on my 93 MR2. The only non-competition 225/50-15 tire I was able to find is a Kumho somethingorother, and according to Discount Tire Direct it's been discontinued. Tirerack.com still shows some in stock, but I have no idea what I'll do the next time I need rear tires.
Benswen
Benswen New Reader
1/24/19 2:46 p.m.
In reply to Will :
You have to get a little creative for SW20 tires.  Tirerack has some good options, but you can't necessarily just shop their MR2 fitments.
I have 195/55 front and 205/55 rear Kumhos on my SW21 street wheels, works pretty well on 15x7 Avalon wheels.  I also have 205/50 Bstone RE71r's that I run front and rear for autox, on 15x6 Millenia wheels in front and 15x7 Drag wheels on the rear.
I'm considering going to BFG Rival 1.5's so I can do a 205/50r15 front and 225/45r15 rear.
K5NZEfXdgJm9Q8pBOUYYPsnPtNyjxTNV7wtTkagbLHyfNr76d3zen6X1DoaiQgA0
