nsogiba
nsogiba Reader
10/14/24 1:10 p.m.
I recently picked up a "forever truck" in the form of a 2005 Suburban 2500. It's optioned exactly as I want and I plan to drive it year round here in lovely Buffalo, NY. The truck has absolutely zero rust on the body and only surface rust on the frame as it lived most of its life in Idaho and Arizona.
Since I would like to keep it as long as possible, I am looking into undercoating options.
My research has led me to Fluid Film and Woolwax. Fluid Film seems easier to apply but washes off more easily, while Woolwax is more robust when applied but is a little more tricky to get on the tough to reach areas.
I have a heated garage with a lift so it is not an issue to perform the job myself, as the cost to buy all the tools and materials is probably about the same as a professional 1 time application.
Amazon woolwax kit
Thoughts, experiences, comments on brands and application methods?
The0retical
The0retical UberDork
10/14/24 2:27 p.m.
Check out the Repair Geek channel on youtube. Lots of good info on prepping and applying lanolin based undercoating.
I'd also look at B'laster Surface Shield. It's a bit thinner, so it's way easier to apply when it is cold out and doesn't wash off as easily as Fluid Film or Woolwax.
adam525i
adam525i SuperDork
10/14/24 3:05 p.m.
I'm planning on hitting my car with Surface shield as well this year, seams like it goes on thinner to get down into seams but then thickens up and lasts longer. I'm keeping an aerosol can on hand to do spots as I pull fender liners etc while working on the car so I can hit stuff when it is convenient but plan on buying a gallon to do a full application in the next few weeks. I did have to change the tip of the can as the stock one constantly clogged on me.
I like the DIY approach, my car has been Krowned in the past and it seems like they hit a lot of spots that are obvious like when you pop the hood but then when you crawl under the thing the areas that are completely missed are apparent. Great, my shock towers are coated under the hood but my rear subframe has rusted out as it has never seen a drop of coating, perfect.
You can also buy those plugs they use at the undercoating shops on amazon if you're going to drill any access holes to get into the rockers etc.
KonaBoss
KonaBoss Reader
10/18/24 9:03 a.m.
Following since I'm on the hunt for a very similar GMT800 2500 'Burb. I have used woolwax in the past with great success. Bought a 5 gal bucket and their professional sprayer with the various attachments. I think I did 6-7 vehicles with that bucket, most of which were large SUV's or 1/2 ton trucks. Holds up well for 2-3 years before touch-up is beneficial in the high-wash areas. My preferred method is to take the vehicle to one of our local rent-a-hoist shops as they usually have a big air compressor and its a much easier job up on a lift. If I'm being meticulous I can usually get the surface prep and application done in 4 hours or so. If you see another good deal on a 2500 send it my way!
93gsxturbo
93gsxturbo UberDork
10/21/24 9:22 a.m.
I was extremely happy with the performance of Fluidfilm on my 2015 Land Cruiser.  I only had it for 3 years, but it looked like brand new underneath when I sold it, even still had the zinc on the fasteners.  In Wisconsin, that never happens.
akylekoz
akylekoz UberDork
11/8/24 1:59 p.m.
 B'laster Surface Shield user here.
Started with my 2017 Buick that had only been through one winter.  I started with a full dosing of it, about 2-3 cans, now I just touch it up at every pre-winter oil change and checkup.  My wife never washes her car so it has held up very well.   If I ever have to remove fasteners they should zip right off, I can deal with a bit of goo on them.
Also started using it on my 2012 Armada, so far they both are holding up great.
buzzboy
buzzboy UltraDork
11/8/24 3:00 p.m.
I'm looking at this for my first New England winter. What are you using to apply?
The0retical
11/8/24 4:58 p.m.
In reply to buzzboy :
Kellsport "Pro" gun is the hot ticket.
Link
You run it at 50-60psi for B'laster or 70-90psi for Woolwax or Fluid Film.
The pressure pot guns have a huge time delay before fluid starts to move that they siphon guns don't have. That makes them really annoying to use for touch ups and ensuring you get the inside of blind areas like frame rails.
nsogiba
nsogiba Reader
11/26/24 8:11 a.m.
Link
I ended up going with the Kellsport gun kit from Amazon and am very happy with the results. Woolwax is a messy product but effective and sticks to everything. The job would have been much easier and more comfortable if I had access to a lift, but since my 2500 is too heavy for my MaxJax I was limited to jackstands. I plan to do the wife's Rav4 this week which fits on the lift easily and am actually looking forward to that job.
UOm1bdcJ0XhcECS1tWlPoR3geijgeUblfxYVICRWtfwk7CDBmB0BOwOUTvsPkfux
